My taskbar which is normally at the bottom of my screen is gone.
How can I get it back ?
Turn you machine off and on to see if it was just a glitch.
If it is still not there after you rebooted, then you may have accidentally deleted it. In any event, the way to reinstate a bottom task panel is to right click the top panel and select "new panel". It will probably default to the bottom of the screen. But, if it does not, then right click the new panel and choose "properties".
I installed a new panel.
Problemo fixed.
