Trying to leave windows and to use Mate 19.04. (Aorus Z390 Master +I9-9900K+Samsung M2), no separate video card. It worked fine for a couple of days (doing silly things just to test the setup) , but then the machine started to reboot if I open Software Boutique or if the Mate Welcome screen opens.
AFAI can tell the logs under /var/log do not reflect any crashes.
I have rotated the 4 memory sticks (using only 1 right now) with no luck.
The problem can be reproduced if using the Mate USB and then executing the welcome screen.
I installed Windows 10 in a separate HDD to run the Intel CPU tests, they come clean.
memtest86+ comes clean with the single stick I have now.
Windows 10 seems to work fine
kubuntu seems to work fine from the USB (tried to install software boutique on it without luck).
Mate seems to work fine if I do not use the software boutique or run the welcome screen.
Nothing is overclocked.
I am tempted to fault the mainboard, but the error is so specific that I am not sure if I am barking to the right tree. I am running out of ideas....
thanks for any help you can provide
Gustavo
