i installed 18.10 and since install my network printer is not visible in printer settings.
With previous versions my printer was always autodetected on first boot.
If i do a
sudo service cups restart
my printer shows in printer settings and works.
But after few seconds the printer disappears and the refresh button won’t find it anymore.
very strange.
any help?
pappl
Reinstalled 18.10 and same problem after first reboot.
Printer is autodetected and stays visible in Live-CD environment.
After install printer is autodetected automaticly after reboot but disappears after seconds from installed printer list.
Workaround:
In Printer settings menu click Add printer dropdown button and click “printer”
Select Network-printers and select the printer with IP-Adress (e.g. Brother MFC… (192.168.1.xxx)).
Select Driverless IPP (ipp/print) and forward.
Try additionally if it still doesn’t work:
Printer-Settings - Server - Check “Publish shared printers connected to this system”
pappl
I use the Epson printer and and it is connected to the system which is really helpful for us. But sometimes it occurs some problem which provide the good service and it is really helpful for us. if you have an issue with printer then go to the printer repair near me to solve all the problem.
