Hello MATE users,
some time ago I noticed our beloved DE has only between 150 - 180 stars on GitHub. So I starred the repository to show some appreciation to the developers for their work. If you already have GitHub account, you can do the same. It will cost you nothing, you don't need to contribute the code to the repository, so do not hesitate to give the star to your beloved DE.
Giving the GitHub Star might look like petty little thing but I think it still has some value. Also the GitHub help says:
Starring a repository also shows appreciation to the repository maintainer for their work.
There is the MATE Desktop project on the GitHub which contains all the related repositories. You can not star the project but you can star any repository. I think it makes the most sense to star the mate-desktop/mate-desktop repository at this point.
