my mate-panel is very unstable. After swithching screens it can disappear. It is still running but nothing shows. The space is reserved so windows don’t span to the top of the screen. A SIGHUP does restart it but does not make it appear.
Also when using the mate-tweak to change profiles it makes mate-panel often crash.
Is this an ubuntu-mate or mate-panel issue ?
Is there a way to reset it? Delete some config file? I tried mate-panel --reset.
