Mate search tool help
Is there a way to search for just files that start with say “gru” so I do not get a listing of every file that has “gru” in the filename?
Yes. Use the Regular expression matching option.
I also found that gru? also works.
@fixit7
Just a tip…
If satisfied with the answer, please check it as the solution.
Thank you
I will do check it off as solved.
I noticed box was checked for all my posts already ?
Did someone else do that ?
You mean like this one :grinning:
If thats not the solution you are looking for, just uncheck it.
No, the checkbox with the checkmark in it.
:thumbsup: :v: :thumbsup:
