Mate terminal don't open after upgrade from 18.04.2 to 19.04
Hi!
I can't open anymore Mate-Terminal after upgrade from 18.04-2 to 19.04.
Before upgrade my system today, 18.04-2 worked good.
I run xterm, then run mate-terminal...
Output: 'error'
relocation error: /usr/lib/x86_64-linux-gnu/libgnutls.so.30: symbol nettle_rsa_sec_decrypt version HOGWEED_4 not defined in file libhogweed.so.4
with link time reference
"/usr/lib/x86_64-linux-gnu" are these files:
libgnutls.so.30
libgnutls.so.30.23.0
libhogweed.a
libhogweed.so
libhogweed.so.4
libhogweed.so.4.5
How can I fix that?
Since you can get to xterm let's run a few commands.
dpkg -s libhogweed4
What version does it show? It should be 3.4.1-1
Now let's run the following:
sudo apt update && sudo apt upgrade -y
When that completes, lets run dpkg -s libhogweed4
What version do we show now?
Let's try running mate-terminal now.
@ franksmcb...
dpkg -s libhogweed4
...shows me: 3.4.1-1
Output-error:
/usr/lib/apt/methods/http: relocation error: /usr/lib/x86_64-linux-gnu/libgnutls.so.30:
symbol nettle_rsa_sec_decrypt version HOGWEED_4 not defined in file libhogweed.so.4 with link time reference
/usr/lib/apt/methods/https: relocation error: /usr/lib/x86_64-linux-gnu/libgnutls.so.30:
E: Method http has died unexpectedly!
E: Method https has died unexpectedly!
E: Sub-process http returned an error code (127)
E: Sub-process https returned an error code (127)
:frowning:
Two moments here:
  1. I can't reproduce your problem - my 18.04.2 LTS virtual machine successfully upgraded to 19.04. All terminals and apt/apt-get work as usual.
  2. It is usually not recommended to upgrade from LTS (this means 5 years of support) to regular (9 months support) release.
Then about debugging.
I suspect that you have self-compiled library in something like /usr/local/lib.
Please add output of the ldd /usr/bin/mate-terminal | grep -E "tls|hog" command to the next reply.
Below is the output from my clean 19.04 system for reference:
$ ldd /usr/bin/mate-terminal | grep -E "tls|hog"
	libgnutls.so.30 => /usr/lib/x86_64-linux-gnu/libgnutls.so.30 (0x00007f9633531000)
	libhogweed.so.4 => /usr/lib/x86_64-linux-gnu/libhogweed.so.4 (0x00007f96317e7000)
and both libraries came from official packages:
$ dpkg -S /usr/lib/x86_64-linux-gnu/libgnutls.so.30
libgnutls30:amd64: /usr/lib/x86_64-linux-gnu/libgnutls.so.30
$ dpkg -l libgnutls30:amd64 | tail -n1
ii  libgnutls30:amd64 3.6.5-2ubuntu1.1 amd64        GNU TLS library - main runtime library
$ dpkg -S /usr/lib/x86_64-linux-gnu/libhogweed.so.4
libhogweed4:amd64: /usr/lib/x86_64-linux-gnu/libhogweed.so.4
$ dpkg -l libhogweed4:amd64 | tail -n1
ii  libhogweed4:amd64 3.4.1-1      amd64        low level cryptographic library (public-key cryptos)
(it would be great if you compare these outputs with your system)
I think I got it...
shows me a wrong path from libhogweed.so.4 in /usr/local/lib...
I removed all files from "libhogweed*" in "/usr/local/lib"...
Output from ldd now:
libgnutls.so.30 /usr/lib/x86_64-linux-gnu/libgnutls.so.30
Many thanks!
Now I can run Mate-Terminal again...
(SOLVED)
