While looking for something else, of course, I came across a setting in mate-tweak
Panel; Panel Features; Enable keyboard LED.
I checked it and low and behold I can see the status of the Caps Lock and Num Lock on my keyboard. This is especially useful with my test Pi as I am using a cheap wireless keyboard which does not have any indicators on the keyboard. My question is…
I see in the notification area a 9 in a circle and an A in a circle. These are obviously num-lock and caps-lock. There is also a two headed arrow (pointing up and down) in a circle. Can someone tell me what this indicates? I have tried various other keys and nothing seems to make it change color as do the num-lock and caps-lock indicators.
Thanks,
Ken
