MESHMIXER problem install
Hello!!
I am new on ubuntu mate… :smiley: and i cant install these pactage from autodesk that i use to prepare files to 3d print…
http://meshmixer.com/linux.html
Some one as installed these ?
Are you running 14.04? Meshmixer has a depends problem with a newer version.
http://packages.ubuntu.com/trusty/libboost-date-time1.54-dev
And that's as far as I can test, I'm not running 14.04.
Are you getting install or depends errors?
The version shown on their website is 64 bit only, do you have a 64 bit system?. :smiley:
yup … im on 64 bit…
the problem is the dependencies…
Are you running 14.04 and what depends?
I have 15.10 installed …
You may be able to force the version that you need using synaptic.
From what I see, libreoffice could be affected, but that may not be a problem.
Make a note of any missing dependencies and look for them here and install them first!:
http://pkgs.org/
ok i will try out using other version
I think that meshmixer should be made aware of this. They need to update.
close source… nahh is not going to happen … :smiley:
I think i am going to intall mate 14.04
