Thanks for flagging these up, I'll look at adding an Install button for the programs that are missing from a minimal install.
For the Additional Themes, these packages are installed:
arc-theme
greybird-gtk-theme
mate-icon-theme-faenza
numix-gtk-theme
numix-icon-theme
breeze-cursor-theme
breeze-icon-theme
It determines the install/remove button by detecting a "main" package - in this case it was breeze-cursor-theme, but this is now pre-installed AFAIK, so I'll change this to check a different package from that list.
Breeze Cursors are no longer seeded, but given they were for part of the 18.04 cycle we should change the package that is used to determine the additional themes are installed. breeze-icon-theme is probably the best candidate.
Is the arc-theme which is installed the one usually found (which has been abandoned) or the fork? The fork has significant improvements and is the one I use just now via its PPA.
All points have been addressed (in development). Except:
Blank Welcome -- this is a more complicated bug with WebKit2, which renders the application.
And this one:
Terminal output would be useful to see exception details please, but it has been working here. Generally, "Storage" might not populate properly if the disk has lots of partitions / is complicated. It needs a re-write really (in the future).
Log appended. “Storage” not being populated is the same on:
Bare metal build of 18.04b1, patched until now;
VM of 18.04b1, unpatched;
VM of 18.04b1, patched until now;
with a minimal install in each case.
From the output it looked as though hardinfo, gparted and/or gnome-disk-utility are the culprits. However, I installed all three, as well as inxi, and there was no difference:
[i18n] Locale Not Available: null (using en_US instead)
[i18n] All translated i18n pages found.
[i18n] Using locale for gettext: null Looks
[i18n] Using path for gettext: /snap/ubuntu-mate-welcome/18/usr/share/ubuntu-mate-welcome/locale/
[i18n] Translation found for gettext.
[Config] Read "autostart" => "True"
[Specs] Detecting graphics vendor...
[Network Test] Establishing a connection test to "http://archive.ubuntu.com/"
[Welcome] Font DPI is: 96
[Specs] Detected: Red Hat, Inc. QXL paravirtual graphic card (rev 04)
[Welcome] Setting zoom level to: 1.0
[Apps] Reading index...
[Apps] Successfully loaded index.
[Config] Read "hide_non_free" => "False"
[Welcome] Snap detected. Using __VERSION__
[Welcome] Version: 17.10.16
[Pre-Install] System is running Ubuntu 18.04 (bionic)
[Welcome] Application Ready.
[Welcome] Successfully pinged: http://archive.ubuntu.com/
[Welcome] Page: splash.html
file:///snap/ubuntu-mate-welcome/18/usr/share/ubuntu-mate-welcome/splash.html
[Welcome] Page: index.html
file:///snap/ubuntu-mate-welcome/18/usr/share/ubuntu-mate-welcome/index.html
[Welcome] Page: gettingstarted.html
file:///snap/ubuntu-mate-welcome/18/usr/share/ubuntu-mate-welcome/gettingstarted.html
[Apt] Package "hardinfo" is not installed.
[Apt] Package "gparted" is not installed.
[Apt] Package "gnome-disk-utility" is not installed.
[Apt] Package "mate-utils" is present.
[Apt] Package "mate-system-monitor" is present.
[Apt] Package "psensor" is not installed.
[Apt] Package "boot-repair" not available. Considered not installed.
[Apt] Package "libavcodec-extra" is not installed.
[Apt] Package "firmware-b43-installer" is not installed.
[Apt] Package "hplip-gui" is not installed.
[Apt] Package "solaar" is not installed.
[Apt] Package "fcitx-sunpinyin" is not installed.
[Apt] Package "fcitx-mozc" is not installed.
[Apt] Package "fcitx-hangul" is not installed.
[Apt] Package "caja-share" is not installed.
[Apt] Package "libdvdcss2" not available. Considered not installed.
[Apt] Package "xscreensaver-gl" is not installed.
[Apt] Package "breeze-cursor-theme" is present.
[Apt] Package "ubuntu-mate-wallpapers-complete" is not installed.
[Apt] Package "polychromatic" not available. Considered not installed.
[Apt] Package "openrazer-meta" not available. Considered not installed.
[Welcome] Command: init-system-info
[Specs] Gathering system specifications...
[Specs] Gathering advanced system information with "inxi"...
[Specs] Gathering Data: Distribution
[Specs] Failed to execute collect advanced information. Is "inxi" no longer installed?
[Specs] Failed to append advanced system information or communicate with "inxi" process.
[Specs] Gathering Data: Kernel
[Specs] Gathering Data: Motherboard
cat: /sys/devices/virtual/dmi/id/board_name: No such file or directory
[Specs] Gathering Data: CPU
[Specs] Gathering Data: Storage
[Specs] Ubuntu MATE is installed on disk: /dev/mapper/ubuntu--mate--vg-roo
[Specs] Failed to gather data: Storage
[Specs] Gathering Data: RAM (Memory)
