Missing ib_iser module for iscsi
Hello all,
I am trying to use open-iscsi to unload my /var/log to an iscsi partition on my QNAP. When I run stuff from the command line, everything works out. But when I use the iscsi partition (currently using lvm2 on that), dmesg starts to blabber about missing ib_iser module, which is needed for iscsi to function properly.
jul 07 19:08:12 haringstad-pi systemd-modules-load[82]: Inserted module ‘iscsi_tcp’
jul 07 19:08:12 haringstad-pi systemd-modules-load[82]: Failed to find module ‘ib_iser’
And, of course, after a while… you get the famous “Login - CTRL-D” message…
Any help would be appreciated.
Jay
