This is a screenshots showing the icons when you click on the menu or right click on the desktop. I was wondering if there was a way to make these icons bigger. I'd also like to know if there was a way to make the icons in the folder to look bigger as well. Last, is there a way to make the icons bigger in the Caja menu on the left hand side/sidebar?
