Need help to fix Theme error (wrong display error) on user account
Hi!
When modifying a theme which
I use, a display error crept in and I don't know how to fix it.
can undo this.
Display error (wrong) non-root (user):
Check mark (background is blue) That is wrong.
See picture:
01-user
Correctly displayed in root (root):
02-root
04-check-mark-is-blue
too big: (Enter field)
03-too-big-enter-field
Can someone help please?
Which file must I edit and which values?
If you still have the original theme, or you can point us to the original, you can use the diff command to see what the differences are between your version and the original:
diff -uprN /path/to/original/theme/directory /path/to/your/theme/directory
Oh yeah. If the theme appears fine on root but not your normal user, that probably means you've been tweaking with a local copy in your ~/.themes directory, so you can use something like this:
diff -uprN /usr/share/themes/Ambiant-MATE ~/.themes/Ambiant-MATE
Of course, if your theme is not called Ambiant-MATE then change the name in the command!
@ gordon, thank you for your effort to help me.
It did not help.
Something is messed up when optimizing my theme.
I have restored my backup of my system which I made 3 days ago and now everything is ok again.
Well, my advice this time is: Keep track of your theme changes regularly. Frequent backups or version control of anything under development are fundamental.
I wish you success in the long run.
