Need longer window for panel items
Is there a way to get these windows so they are longer?
They are part of the desktop buttons on the bottom of my screen.
I think you are asking about modifying the panel? I have had mixed results with that but I would start here and check the layout you are using.
/usr/share/mate-panel/layouts
Why not just create a new panel? Or sub-panel if that's more to your needs.
To clarify, to you mean
  • larger "font size", or
  • instead of 150px by 30px, you want 150px by 80px?
The latter is not possible, to my knowledge. :slight_smile:
Unfortunately it is Door #2.
I have lots of space on my panel, so it would be nice to make those "windows" wider so they show more of a directory name.
If the directory is in the window title, then the mouseover hover on the "button" should display the full path, I think:
