Need some help editing system menu
As per title.
On the Mate system menu, there are two items: "help" and "about mate". I am wanting to remove these two items from the system menu on a Frankenstein Linux system /i am building which includes Mate Panels, but isn't actually the Mate Desktop. But, there is no obvious way to remove these items that I have found.
If anyone knows how, I would be grateful for this information
See screen-shot below:
I was in a 16.04 VM so tried renaming these and it worked. They didn’t originally have “.disabled” in their name:
/usr/share/applications/About MATE.disabled.desktop
/usr/share/applications/Help.disabled.desktop
Do they exist in your Frankenstein? And be warned it’s an uneducated hack. :relaxed:
Cheers Bill. Deleted them and voila. They’re gone from the menu…:slight_smile:
The system is actually Ubuntu Studio which is ostensibly XFCE4.
But, I have swapped out XFCE4-Panel for the Mate-Panel and have also replaced Thunar with Caja
It’s working pretty well in a VM.
How do you remove the lockscreen buttom?
Install dconf-editor, if it is not already installed:
sudo apt-get install dconf-tools
Then open dconf-editor (it’s under “applications/tools”)
Navigate to “org/mate/desktop” and check “disable lock screen”
