I have a new ISP, and have been trying to connect wirelessly. Ethernet works fine. There is no applet in the top bar to select a source. I added a Notification Area, which shows up as 3 little dots; there’s no volume indicator, either.
I’ve tried just about every suggestion to make it visible, and finally reinstalled 17.04. The applet was there and i successfully connected wirelessly. Restarted and no applet, and I’m using Ethernet again, with no way to connect wirelesly. I’m unable to use my printer until I get this problem fixed.
Is there something in my /home folder which could cause this?
Has anyone else had this problem?
