Hello
I disabled notifications about being connected and disconnected to a Wi-Fi network by clicking on the “Don’t show this message again” button. Is there any way to enable those again?
Hello
Hi Snjeshko
Please open a terminal by pressing
Ctrl + Alt + t
and enter
gsettings list-recursively | grep nm-applet
Are connect and disconnect mark true? If so, you need to change that to false. In terminal enter:
gsettings set org.gnome.nm-applet disable-disconnected-notifications "false"
and
gsettings set org.gnome.nm-applet disable-connected-notifications "false"
That did it. Thanks!
