Hi, 20-10 runs great even on the 4GB RAM RPI4, very smooth, with overclock 2.2GHz. I do a lot with the /dev/ttyUSB0, I miss it in this release. Does anyone have any idea?
[edit1] As I use ESP8266 I can now see with some boards connected the /dev/ttyUSB0 but no connection is possible. The driver must be there, but still does work strange?
[edit2] Now using "sudo" it works, but not without.
[edit3] I was wrong. In difference to the RaspiOS is that the actual user needs to be part of the "dialout" Group. This fixed my problem
Good luck, Herbert
