Any one care to hazard a guess on why my battery icon has gone funny and obviously the authentication key icon thing has as well. Cheers in advance for any help
Edit: probably should have added all i did was upgrade from 16.04. to 16.10
Hi wutwut; welcome to our forums
This could be a problem with the theme your running. Mate 16.04 used gtk2/3 and 16.10 uses gtk3 only. So try another theme. Mate-tweak can be used to change the panel layout or go to “Appearance” GUI in the main menu and change the theme.
Please post any questions you may have.
Thanks for helping so quickly
I tried a number of different themes etc but as you can see below the authentication keys icon still goes funny, also I'm not 100% sure but the shut down menu looks a bit squashed to me but that could just be me?, i thought maybe something might have gone bad with the upgrade so i did a fresh install via usb and I'm still getting the same issue
