Ooops... sound no longer works in 16.10
Hello. I did an apt-get update and upgrade in 16.10 and now I can’t get any sound through Firefox. I can, however, get sound through VLC. Any advice would be highly appreciated because I listen to radio stations 24/7 through Firefox.
UPDATE: I installed pavucontrol and found the problem. I hope this helps someone else.
OP solved the problem himself but I cannot put a solved tick in the first post!. :smiley:
