Hi everyone,
i use owncloud to synchronize some personal data.
For about half a year the tray icon is missing.
Does anyone know a solution for that?
Thanks for any help
Hi everyone,
Thanks for any help
I have owncloud client running on UM 16.04 and have selected Starten beim Systemstart (Launch at Startup), then upon reboot, the cloud icon appears in the panel. Give it a try … HTH
Thanks for your help but unfortunately it did not work.
Hi @PatRick08,
try adding it manually to Startup Applications:
Control Centre > Personal > Startup Applications > Add > Browse > File System > usr > bin > owncloud
This seems to be a known issue (and the second time it’s happening) and they are working on a fix. So I guess you better wait for updates.
See:
https://github.com/owncloud/client/issues/4828#issuecomment-272092590
https://github.com/owncloud/client/issues/5432
All right thanks for your help.
