The top panel is hiding the top of my window. The top of the window stayed below the panel up until recently. Now the top slips under and is obscured; so I can no longer use a top panel. Is there a way to fix this? BTW, I’m using Compiz.
I switched to Mutiny then back to Familiar. This fixed it. How do I close this?
Marking solved is good enough.
FYI the issue you described could also potentially be mitigated by just grabbing the window anywhere with the ALT+LEFT CLICK trick if it happens again.
