Hello Folks.
At some time soon I'd like to make a change to my display such that the desktop is bigger than my physical screen and it moves when I move the mouse cursor to its edges.
Searching for 'panning' here was hilarious as apparently that function sees it as the same as 'panel' and that was all it returned.
Searching generally brought me to this:
https://wiki.ubuntu.com/X/Config/Resolution#Panning_viewport
Which says:>
Panning viewport
If you want to have a panning viewport, i.e., a virtual screen that's bigger than your physical screen that moves when you move the mouse to the edge ("zoomed in" view) specify the desired physical resolution with --mode and the virtual screen size with --fb and panning area (typically same as virtual screen size) with --panning.
For example,
$ xrandr --output VGA1 --rate 60 --mode 800x600 --fb 1280x1024 --panning 1280x1024
Which looks good but of course I have no idea if there are specifics pertaining to Mate which may be missing or if there are other details I should know - so I'm asking for help from those who may know alot better than myself here.
Thanks for any helpful replies !!
