When I try to move photos from my external to my internal disk I get the message permission denied.
How do I get the required permission please
regards Bob
regards Bob
In terminal:
gksudo caja
Should work now, just be careful what you do. When using caja as a superuser (gksudo) the safeties are off and a mistake can really hurt things.
Hi @Robert_Walder,
are you logged in as guest or other user?, if you are not logged in as the main user (admin), it won’t let you do anything on an administrative level!.
