Try the following command in a terminal.
lsb_release -a
Highlight the results and use ctrl-shift-c to copy . Paste into a new pluma file to check and post back here. Otherwise, a screenshot would be just fine.
lsb_release -a
Also see -
You're running Focal Fossa. I added a tag to the title of this post to ID your OS.
So what did I learn from all this?
Not bad for one bug.
At the end of this topic, I must warn you that Preferred Applications has rarely ever worked for me to set anything. Far better to use Properties, Open With as I remarked in post #2 above, then check Pref. App. to see how it looks. Glad that you no longer have to look at Image Magick's splash page.
Really? Mate has a bug that prevents setting other Preferred Apps sometimes? Strange. So far, the PDF pointer is the only one I've run into that couldn't be changed. I'll keep a look out for others. Just hope I can remember what fixed it.
It wasn't a matter of a problem of looking at the splash screen, it was a matter of productivity suffering due to a slow down every time I'd quickly click on a document as I was collating only to find it wouldn't open. Then have to back up and choose Atril.
You used the term "bug", I did not. I do a lot of things that tend to mess with how operating systems work. Because I've been doing this for more than a few years, I don't think that my inability to set preferred applications with MATE's app is any big deal.
I usually know what to do to correct this app as well as a few others. Look at post #8 where I misspelled Atril as Arril in the screenshot. The typo was a result of fixing something too fast. How embarrassing...
Glad your productivity is back on track.
