Plank as panel is covering top panel
I use one of the layouts, which take use of plank as a dock.
I positioned it on the left hand side. If I use the option “fill” the plank covers the top left button.
My question: Is it possible to adjust this behaviour that it does NOT cover the top panel?
I now that I can design a panel on my own (without using Plank) - but that’s not what I want.
Cheers
Johkra
Possibly not what you’d like >>> try Alignment = fill, icon alignment = center
