eh? why am I seeing deepin-notification here?
you can install adwaita icon theme by
sudo apt install adwaita-icon-theme
i use deepin-screenshot
geets@geets-PC:~$ sudo apt install adwaita-icon-theme
[sudo] password for geets:
Reading package lists... Done
Building dependency tree
adwaita-icon-theme is already the newest version (3.28.0-1ubuntu1).
The following packages were automatically installed and are no longer required:
linux-headers-4.18.0-15 linux-headers-4.18.0-15-generic
linux-image-4.18.0-15-generic linux-modules-4.18.0-15-generic
linux-modules-extra-4.18.0-15-generic
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
let me test if installing deepin-screenshot interferes with my notification
be back shortly
already looking interesting!
root@um:/home/gordon# apt install deepin-screenshot
The following additional packages will be installed:
dde-qt5integration deepin-notifications deepin-shortcut-viewer libdframeworkdbus2 libdtkcore2 libdtkwidget2 libdtkwm2 libgsettings-qt1 libqt5multimedia5 libqt5sql5
libqt5sql5-sqlite libqt5xdg3 libqt5xdgiconloader3 libqt5xml5 libxcb-composite0 libxcb-damage0 qt5dxcb-plugin
The following NEW packages will be installed:
dde-qt5integration deepin-notifications deepin-screenshot deepin-shortcut-viewer libdframeworkdbus2 libdtkcore2 libdtkwidget2 libdtkwm2 libgsettings-qt1
libqt5multimedia5 libqt5sql5 libqt5sql5-sqlite libqt5xdg3 libqt5xdgiconloader3 libqt5xml5 libxcb-composite0 libxcb-damage0 qt5dxcb-plugin
I have read somewhere.....UM is a GTK friendly distro and not a QT5
its the post about vlc and mpv not sure if it is relevant but I am new here myself
i uninstalled deepin-screenshot and the problem went away but it's weird because it all worked on my previous installation on the same hardware
maybe just removing deepin-notifications will work?
well I am stumped.
after installing d-screenshot without reboot....my notifications for usb removal still worked as normal....and I was away doing 2 reboots to test again with equal success.
Can I mention that I use mtpaint to take time delayed screenshots if UM screenshot app is not to your liking.
If you believe deepin-screenshot is the culprit....then it would also make sense to remove deepin-notifications.
There a lot of screenshot apps and mtpaint does not use notification daemon.
thank you for your help
haha, I reinstalled deepin-screenshot and removed deepin-notifications and it all works fine now
