Possible memory leak in mate-panel?
Reproduced in Fedora 24 with MATE 1.14.1
Reported upstream @ https://github.com/mate-desktop/mate-panel/issues/479
I have the same problem on Debian 8 with mate desktop. mate-panel eats tons of memory and cpu till crash my pc.
So for those of you that haven’t followed the conversation on github: it turns out the leak came from GTK+, not mate-panel directly. The code has been patched upstream to mitigate this issue but the changes have yet to reach the LTS, they must first undergo the SRU process.
And I’m going to try and progress that SRU process.
Alright.
Thanks to @Wimpy, @tsimonq2 and the guy who developed the GTK patches, I had the pleasure to see this in the updates today:
This issue is now fixed in Xenial \o/
:smiley: \o/
Thanks for the ping. :wink:
I had memory leak problems using Ubuntu Mate 18.04.1 after installing it yesterday. What worked for me is stopping firejail and firetools and the memory leak stopped. So, if you’re using firejail, then it might be the cause of memory leaks. I think this is a problem with the Bionic Beaver rather than firejail. I find firejail to be a great piece of software but it causes a lot of problems with 18.04.1.
Hi, do any of these tools display an icon in the notification tray? How did you determine it was a memory leak?
I noticed using psensor; I used psensor’s ability to warn me when memory falls after a certain low threshold. However, after using Bionic Beaver after a couple of hours without Firejail, it seems that it is not a problem with the OS, but with Firejail needing more than 8gb of RAM, which is the amount I have. I thought that it is a problem with the Bionic Beaver after reading about a lot of people having problems with memory leaks after installing the 18.04 version. Bionic Beaver works great with 8 gb of RAM; if someone has memory leaks with Bionic Beaver, I recommend:
  1. Upgrading the hardware to a minimum of 8 gb of RAM
  2. Not using Firejail beyond 16gb of RAM
Not only Ubuntu 18.04, but also web browsers need a lot of RAM these days, so upgrading the RAM seems necessary to me.
I wrote this in case someone else has the same problem. So, I hope this helps.
Cheers.
