Hay all,
i am using raspberry pi with Ubuntu mate OS along with displays of 5 inch display and 3.5 inch display.
There is a problem with the resolution of displays, that is when I open/select an folder or any other application the window size remains same as the size for the 15 inch display of laptop. Is it any option of reduce the window size according to the display size.
Since the display is small the windows open goes out-off the display size for both 3.5 inch and 5 inch display. It is little difficult for me, when i run a python code to capture an image (which is my project work) the half of the window goes out-off the display. there is no problem when I run the program in laptop the window size has no problem, but when comes to the this both display the windows goes out off the display resolution.
I like to know is it possible reduce the window size according to the display size?
Thanks in advance
