Hallow Every One
My issue this time is that my Libre Office Writer is just totally BLACK.
I have uninstalled and reinstalled the program three times now but the document is as you can see just black.
- Any One ???
Regards
SpacePunk
Hallow Every One
Did you try to remove libreoffice folder from .config folder?
@brokoli my man, wheres the ,config folder ?
& I feel pretty stupid…
But then Again.
Regards
SpacePunk
It is in your home folder. To show it in Caja press ctrl+h as all folder that have name .example are hidden.
@brokoli My Man
Thank`s a lot, every thing seams normal now.
Regads
SpacePunk
