Question about "sysctl"
Hi!
Does it make a difference if in the file
/etc/sysctl.conf
I enter
for example
vm.dirty_ratio = 10
or
vm.dirty_ratio=10
in the file?
Did a test, also:
sudo sysctl -w vm.dirty_ratio = 10
sysctl: "vm.dirty_ratio" must be of the form name=value
sysctl: malformed setting "="
sysctl: "10" must be of the form name=value
sudo sysctl -w vm.dirty_ratio=10
Output message:
vm.dirty_ratio = 10
It would be great if someone could enlighten me on this.
IMHO there is no any difference:
SYSCTL.CONF(5)
NAME
   sysctl.conf - sysctl preload/configuration file
DESCRIPTION
   sysctl.conf is a simple file containing sysctl values to be read in and set
   by sysctl.  The syntax is simply as follows:
          # comment
          ; comment
          token = value
   Note that blank lines are ignored, and whitespace before and after a  token
   or value is ignored, although a value can contain whitespace within.  Lines
   which begin with a # or ; are considered comments and ignored.
   If a line begins with a single -, any attempts to set the value  that  fail
   will be ignored.
