Radiant-MATE Dropbox icon
If you use dropbox you’ll know that the folder that’s added to your home folder is just a default one. Here is one I made to keep the theme going.
https://www.dropbox.com/s/erv7ocy9o211ho9/dropbox.svg?dl=0
Move/Copy this to:
/usr/share/icons/Radiant-MATE/places/64/
You can then select it as the new icon for dropbox.
