Howdy,
I'm running Ubuntu MATE on the Raspad 3. It's the best distribution for my needs so far, and seems to play better on the touchscreen even than Gnome 3 so far... One of my main immediate kludge needs is to disable drag and drop, or optimally, replace single finger screen drag with double finger. This is normally mainly an issue in Caja. Caja will think every long hold is a drag and drop, which results in annoying displacement of files. I would rather this be a right click or keyboard action, as I copy or move using the CLI anyway.
Thanks for any help on this.
System info
OS: Ubuntu 20.04.4 LTS aarch64
Host: Raspberry Pi 4 Model B Rev 1.4
Kernel: 5.4.0-1059-raspi
Shell: bash 5.0.17
Resolution: 1280x800
DE: MATE
WM: Metacity (Marco)
CPU: BCM2835 (4) @ 1.500GHz
Memory: 7759MiB
