I have a raspberry pi 3 B hardware running ubuntu mate 18.04 (amfhf, 32bit). then the pi 3B device didn't work with audio through built-in 3.5 speaker output. Even though using rasp-config, I setted the audio path to built-in 3.5 speaker output, I could not hear any audio with 3.5 speaker-output when playing the video using VLC player or GNOME MPV player. the video did work with the pi device but audio did not work with speaker output. When I setted the audio voice to auto mode using rasp-config, the same problem happened. However, I did not tested the pi with hdmi audio path because I have only hdmi monitor with not voice but video function.
Any help? Is there anybody with the same problem with audio stream?
Then,
