Hi all,
"Is it normal for the raspberry pi 4 to overheat on Ubuntu Mate 20.04 when sitting at idle?"
I'll explain...
I have the Pi 4 4gb model. It has the Raspberry Pi OS (Raspbian) installed currently with an idle temp of low 40oC. I installed the Ubuntu Mate "64bit" version to better utilize the ram for performance, but at idle, the temp was in the 50s after a short time of using it and stopping. I even outfitted the Pi with a Flirc case for cooling but the temps are still a little strange.
I don't know, maybe if I use the 32bit version, the temps would fair better overall.. At a sacrifice of performance?! I'm not sure what version the Pi OS is whether it's 32 or 64bit.
Raspberry Pi OS is a great system to use but I prefer Ubuntu personally, especially Ubuntu Mate since I used it before in the past. Just looks a lot sleeker and clean designed. With tons more options for customizing the look.
Thanks everyone!
