Raspberry pi and UM 22.04
Hello friends. I have been having problems getting a pi4 to boot UM 22.04. Not sure if i'm burning the image correctly? Could someone explain the best way to burn the image. Thanks
Hello Drc
The recommended method is to use "Raspberry Pi imager" https://www.raspberrypi.com/software/. :slightly_smiling_face:
I've used BalenaEtcher several times, both for SDcard and USB device.
Without any evidence of what you tried, and what the symptoms were it's a job to go further - but with USB device, have you checked which version Pi4 you have?
I found the problem. I had 2 used SDCards that appear to be corrupt even after they were formatted. Using a new SDCard and everything works. Thanks for all of the help.
