Redshift, how to get it working?
Hello everyone I was wondering how redshift works, I currently have it installed but it does not seem to do anything to the color temperature. I also tried watching a video on how to configure it but nothing is working
Thanks so much
By default redshift checks your time zone and adjusts according to its best guess at your preference.
Try adjusting the temperature directly with, for example
redshift -O 3500'
Lower values for the temperature give you a darker display.
Will it automatically adjust the temperature
Thank you
The is not really a MATE issue but…
Check the file redshift.conf. Probably in your .config directory.
The file is well documented and explains how redshift determines your display temperature. I prefer to set it directly at will. I use these aliases. (Some people are horrified by my use of dots instead of underscores but I don’t care. It’s just me here.)
alias bl='redshift -PO 3500'
alias bl.1='redshift -PO 2700'
alias bl.o='redshift -O'
alias bl.x='redshift -x'
