Ok, I will try it out.
Lots of finds?
apt search appmenu
Sorting... Done
Full Text Search... Done
appmenu-gtk-module-common/bionic,bionic,now 0.6.94-1 all [installed,automatic]
Common files for GtkMenuShell D-Bus exporter
appmenu-gtk2-module/bionic,now 0.6.94-1 amd64 [installed,automatic]
GtkMenuShell D-Bus exporter (GTK+2.0)
appmenu-gtk3-module/bionic,now 0.6.94-1 amd64 [installed,automatic]
GtkMenuShell D-Bus exporter (GTK+3.0)
appmenu-qt/bionic 0.2.7+14.04.20140305-0ubuntu2 amd64
application menu for Qt
budgie-appmenu-applet/bionic 0.6.94+repack1-1 amd64
Application Menu plugin for budgie-panel
gnome-shell-extension-multi-monitors/bionic,bionic 0.00~git20171014.1.df5d6e4-1 all
Better support for additional monitors in GNOME shell
indicator-applet-appmenu/bionic 12.10.2+17.10.20170425-0ubuntu1 amd64
Clone of the GNOME panel indicator applet
indicator-appmenu/bionic 15.02.0+16.10.20160927-0ubuntu3 amd64
Indicator for application menus.
indicator-appmenu-tools/bionic 15.02.0+16.10.20160927-0ubuntu3 amd64
Tools for debuging application menus.
libappmenu-gtk-parser-dev-common/bionic,bionic 0.6.94-1 all
Common header files for GtkMenuShell to GMenuModel parser
libappmenu-gtk2-parser-dev/bionic 0.6.94-1 amd64
GtkMenuShell to GMenuModel parser (GTK+2.0 development files)
libappmenu-gtk2-parser0/bionic,now 0.6.94-1 amd64 [installed,automatic]
GtkMenuShell to GMenuModel parser (GTK+2.0)
libappmenu-gtk3-parser-dev/bionic 0.6.94-1 amd64
GtkMenuShell to GMenuModel parser (GTK+3.0 development files)
libappmenu-gtk3-parser0/bionic,now 0.6.94-1 amd64 [installed,automatic]
GtkMenuShell to GMenuModel parser (GTK+3.0)
mate-applet-appmenu/bionic,now 0.6.94+repack1-1 amd64 [installed,automatic]
Application Menu plugin for mate-panel
mate-hud/bionic,bionic,now 18.04.8-0ubuntu1 all [installed,automatic]
Run menubar commands, much like the Unity 7 HUD
vala-panel-appmenu/bionic 0.6.94+repack1-1 amd64
Application Menu plugin for vala-panel
vala-panel-appmenu-common/bionic,bionic,now 0.6.94+repack1-1 all [installed,automatic]
Common files for Application Menu plugins
vala-panel-appmenu-registrar/bionic,now 0.6.94+repack1-1 amd64 [installed,automatic]
DBusMenu registrar for vala-panel
xfce4-appmenu-plugin/bionic 0.6.94+repack1-1 amd64
Application Menu plugin for xfce4-panel
