I have a persistent obsolete object on the panel. The application was removed several updates ago and I see errors mailspring.desktop not found
I have installed the dconf-editor through which I can see the offending item but I do not see an option to delete it.
I have dconf dump
ed to a file, removed the offending object from the dump file and then reloaded the edited file -- but the offending object continues to offend.
How do I rid myself of this thing?
