Is it possible to remove or autohide the forum title bar?
I could use the real estate
I would respectfully disagree. I think that would be a step backwards. No one-click away from notifications, no easy access to menu and no reminder what topic we’re on.
It’s not like it’s in the way of text, there’s enough room for reading a few posts.
If you really want to remove it, delete CSS position: fixed
from .docked .d-header
. There may be an extension for your browser to do that sort of thing.
Well, when you put it that way
I’ll give CSS a look, thanks.
For those that don’t know, press F11 for full screen which will give you more web browser space!.
