This is a request for help; I'm probably asking in the wrong place (so apologies!). Move/delete as appropriate.
I'm asking here hoping someone knows how to download from iso.qa.ubuntu.com their test results. I don't want to upload anything (I'll use a browser for that).
My first request on Ubuntu Forums (https://ubuntuforums.org/showthread.php?t=2422536) hasn't got a response; and I've noted Ubuntu-MATE has some really active testers - thus my request-for-help here Hopefully one of you uses, or has used the feature I want to use
From Ubuntu Forums
I want to download my QA-testing results (particularly comments, but bug numbers would be great too), but have had no luck trying to use the example code found on http://iso.qa.ubuntu.com/qatracker/api (or the code it points to found at https://code.launchpad.net/~ubuntu-q...thon-qatracker).
As I don't code in python, it's possible it could be something simple, but I get either errors or no results.
Does anyone have a simple script that they can provide to me that will download a users (ie. mine) QA-tests recorded for a testcase (eg. Lubuntu 19.10 all, or just 'live session' tests). I only want to read data so I don't need authentication, and I'm hoping to get it in a series of small text files, OR a large text file, I can
grep
to extract what I need.
Any help would be appreciated. I'm hoping a Ubuntu-MATE QA-tester already uses this feature; and I'd really appreciate a copy of your script (minus any authentication used of course)
With much thanks, Chris.
([guiverc] usually found in ubuntu-news, lubuntu etc on irc)
