First of all, let me say how incredible this distro is on a Raspberry Pi 2. The RPi foundation should seriously consider making this the “default” distribution, it’s so much simpler and nicer to look at than Raspbian.
I’ve been running it for a few days, I’ve got my Pi slightly overclocked and its been running smooth as butter. But I did experience a lockup recently (probably due to my overclock). The system completely stopped responding and I had to physically unplug it from the wall. Since then, FireFox will not start, I get a dialog saying there was an unknown error every time I try to launch it. Also, the Ubuntu Software Updater will not start either. I noticed this when trying to go in and uninstall/re-install FireFox. I get a similar message and the option to try and restart it, which doesn’t appear to do anything.
I need to completely remove and reinstall these apps. Is there something I can do to fix them from the terminal, or do I need to re-flash the entire system?
Thanks and keep up the good work!
