Installed one today on RPi 3.
Some feedback:
Screen for install had very low resolution (640x400). Several config windows (incl ubiquity post-install configuration tool and wifi connection dialog for WPA2 with PEAP auth) are going off-screen and are not re-sizable, which makes navigating a nasty guesswork.
Had to uncomment #hdmi_drive=2 to get sound working, HDMI audio out was not detected under sound settings, even after that, but the audio started working
Except for that, everything working A-OK.
Compared to the last RPi install I did, that one was way less painful. Great job from @Wimpy and the team!
