RPi, Ubuntu mate, utorrent
Hello all,
I haven't touched Linux for a long time and decided I needed to update my experience. I have a RPi, and have installed raspbarian and deluge but it doesn't quite do what I want.
So my question: if I install Ubuntu mate on my RPi will utorrent (Ubuntu version) run OK?
(Google says that utorrent won't run on a RPi as it doesn't support the ARM processor.)
If they don't have a version for arm then you can't install it. Only if you manually compile it yourself
You can see if any of these will work for you:
ktorrent/bionic 5.1.0-2 armhf
BitTorrent client based on the KDE platform
qbittorrent/bionic 4.0.3-1 armhf
bittorrent client based on libtorrent-rasterbar with a Qt5 GUI
