The RPi2 and the monitor both work just fine - OSMC renders perfectly fine in the correct resolution. The monitor is hooked up with a DVI cable through a DVI-HDMI adapter, if it matters.
I’ve gone through all of the graphics related config.txt suggestions and troubleshooting I could Google-up:
un-commented disable_overscan=1
manually set monitor’s optimal resolution with hdmi_mode=35 (1280x1024@60Hz) and hdmi_group=2
What’s confusing me is that Ubuntu seems to think it’s outputting 1280x1024 - according to xrandr -q and the monitor preferences - but the monitor clearly disagrees, as it’s displaying the “Use optimal resolution” warning message in the menu.
Are you refereeing to resetting the monitor to default factory settings in the OSD menu? If that, then yes, but that doesn’t really do anything - it only resets the color presets and brightness levels.
I have the same issue, but my monitor is 1680x1050 and xrandr matches. The monitor information tab on OSD reports 1952x1050 @ 60 hz.
I am using a HDMI to DVI cable.
Any ideas?
