Is there a way I can run both commands for this launcher?
amixer -D pulse sset Master 60%
kblocks -qwindowtitle %c
Not sure I understand your question correctly, but in case I did - you can try adding && between the two commands and see if it works.
Unfortunately It did not work.
Hi
Make a script inside /opt/ with your 2 lines like this (let's say /opt/mylauncher.sh ):
#!/bin/bash
Next make it executable :
sudo chmod +x /opt/mylauncher.sh
Next call /opt/mylauncher.sh
inside your launcher.
Sorry to arrive late, but I thought I should tell you the solution I use.
Just execute the shell, which executes those two commands:
sh -c "amixer -D pulse sset Master 60% ; kblocks -qwindowtitle %c"
This actually might work a little better than @olek's suggestion, because in a shell script %c
is usually meaningless; I think he may have meant to include "$@"
instead?
Thanks, your solution works better since I can add it directly to the panel instead of having to write a separate bash script.
