Running updates in 15.10
A quick question on when to do certain updates… I install updates a couple times a day if they are available. Occasionally there are some held back in which you have to run dist-upgrade…
My question is, should I keep running the dist-upgrade packages regularly or hold off while testing the Alphas?.. I have been doing it lately but thought to myself I should maybe verify…
Cheers.
Yep, you want to dist-upgrade.
