Sceen resolution under minimum reqs
Hello, I want to install this distro in an asus eePC but my screen resolution is 1024 x 600. I want to know if i do install it there is gonna be real issues or not. Thank you.
Your best bet would be to try a Live CD/USB, and if it works with the programs you use, you’re good to go.
With such a low height dimension, you may find windows are very wide in width. Moving the panels to the sides, auto hiding or using the dock may be a good idea to maximize as much of the screen space as possible.
