How do I prevent computer screen from dimming when I am on Zoom? Commands "Never" on Power Management Preferences/On AC Power do not seem to work.
Hi
There is a tool you will like :
─[olek@lenovo_apbook08u]─[~/Downloads]
└──╼ $dpkg -l | grep caffei
ii caffeine 2.9.4-1 all prevent the desktop becoming idle in full-screen mode
You can start it in a indicator, and next enable or disable desktop idle.
Thank you. I have already downloaded it, will try later.
Thanks again.
