I could use a script to kill some processes.
I mainly have the following open:
Firefox, Thunar, Geany,
I think killall is what I need.
Do you want to kill
I do not want to kill my system.
What is all non-OS?
Assuming only one User session, either all children of your open Mate session (first 2 commands below), or all children of each identified terminal session (3rd command below):
I forgot one view: Applications Launched from Panel "button":
For that last one, give this a try (selective killing):
#!/bin/sh
if [ "$1" = "--debug" ] ; then debug=1 ; else debug=0 ; fi
me=$(whoami | cut -c1-7 )
panelPID=$(ps -ef | awk '{ if( $8 == "mate-panel" ){ print $2 ; } ; }' )
test ${debug} -eq 1 && echo ${panelPID}
ps -ef | grep -v 'mate-terminal' |
awk -v ppid="${panelPID}" -v user="${me}" '{ if( $3 == ppid && $1 ~ user ){ print $0 ; } ; }' |
while read line
do
if [ -z "${line}" ]
then
exit
fi
pid=$(echo "${line}" | awk '{ print $2 }' )
name=$(echo "${line}" | awk '{ n=split( $8, path, "/" ) ; print path[n] ; }' )
echo "\t Process:"
echo "\t reported: ${line}"
echo "\t application: ${name} [${pid}]"
echo "\t Kill ? [y|N] => \c" ; read ans <&2
test -z "${ans}" && ans="N"
case "${ans}" in
y* | Y* )
kill -s HUP ${pid}
test $? -eq 0 && { echo "\t\t\t Terminated with HUP signal ..." ;
kill -s INT ${pid} ;
test $? -eq 0 && { echo "\t\t\t Terminated with INT signal ..." ;
kill -s KILL ${pid} ;
test $? -eq 0 && { echo "\t\t\t Terminated with KILL signal ..." ;
* ) echo "\t\t Ignoring process for '${name}' ..." ;;
esac
done
